blown diff:(
  • blown diff:(
    so i blew the diff today.... F*$^(#$*&^&*%#^&*#^()#)^*(&%@^&()%)^*(%#^()*#%^)&( %@#^@)#%&(%@^()&!!!!!!
    not to worry though.. i got my sisters mk4 to drive and it's still under warranty
    my assumption was that the diff bolt kit that was put in, hadn't been done correctly, so one of the parts fell out and chewed up the diff.
    so now i have some nice holes in the housing and no oil in the box.
    LOL
    '76 Golf LS Swallowtail 4dr
    '76 Golf Swallowtail 2dr
    '89 Golf GTI 16V 2dr
    Ouch! Depending on what you want in a gearbox there's a few options, the cheapest being a CHB/E box out of a Cordoba.
    Only $125 at Imlachs.
    If your box is something special you can rebuild it into the CHB/E box casing.
    If you're going to toss that one in the bin, I'm always on the lookout for 020 parts to add to my collection.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
      Well I have a CHB for some unknown reason:S
      Would LOVE a 2Y!! Original for my valver but hard to find
      It al depends on the extent of the damage. The gears may be chewed also, I don't know.
      Ill try to take it to the guys who did the g-box and get it all under warranty seeing as they did put the diff kit in.
        What were you doing to blow the diff??
          Yeah right a bolt came loose, you were ripping reverse skids out the front of your local high school weren't you?
            Ratio's are awesome, after 2nd gear its 5/600rpm between to the next gear.
            What are the CHB's like?
            That's what came to my mind when I saw the thread title
            HAHAHA
              Actually driving relatively sensible for once!!
              Thinking about it. after the box rebuild, I had an issue with it, so it went back. They said a bearing had lost some balls.... So maybe some balls were still in the box and they worked its way to the diff after months of driving.
                thats your hand grenade right there buddy... warranty please !!!
                Lots of MK 1 Scirocco's...
                Cheers,
                Grant...
                  1st gear, hand brake up, side step the clutch at about 4000rpm, white smoke, left and right on the wheel, grab second and hose away yeah!
                    such a sad sight her first ride on a truck
                      so turns out the ~20mm hardened and ground diff shaft cr*pped itself. not happy
                      BUT the diff teeth aren't damaged one bit, Woo!
                      must have had a decently hard life, before my ownership.. or just the shoddy germans!!
                      more money down the sinker
                        Apologies if this annoys you, but how much did you pay for the initial rebuild? (PM me if you want)
                        Was it a full on, replace every internal part of the box?
                        Scares me to think what my box is like inside after 300K.
                        HAHAHA
