So before replacing my Valve Cover Gasket (including replacing 3 knackerd studs) i cleaned the many moons of oil that had leaked down behind the valve cover near the fuel injectors. The oil leak appears to be fixed however I think while cleaning off the excess oil it has dripped down onto the manifold and now there is a lot of oil burnin (whitey blue smoke) coming from under the intake manifold, I assume this is just oil burn, but should i just let it burn off or try and clean it off somehow? where are the likely places that would need attention.
Ive had a bit of a search on this around about and this is usually the case however someone mentioned it could be an exhaust manifold leak but it doent look like it, any thoughts?
Simon
Simon
