changing clutch on a mk2 golf gti 8v
  • changing clutch on a mk2 golf gti 8v
    so i got all parts but these
    Pushrod, clutch release.
    Bushing, clutch pushrod.
    Seal, clutch pushrod.
    do i need to replace these aswell when doing a new clutch?
    The pushrod itself is probably alright, pull it out and check it. Has to be worth getting the seal though, not sure if the bushing is a common failure, not heard that it is.
    Be bad to find the seal is shot and not have one to hand. Job stopper.
      Rear main , input shaft seal, and starter bushes classic job stoppers
      Jmac
      Alba European
        Wait and get the seals as said above. Good advice from above. I bought a car when back in the uk that had 'no clutch', the pushrod had worn thru the tin center disk so replace that to! You should get one in the kit! Good luck!
        Travelling in our Overland Truck somewhere in OZ
        2017 VW Amarok V6 Ultimate
        1995 Mercedes 1222A Overland Truck
        1991 VW Citi CTi 1800i
