mk2 Brake Upgrade
  • mk2 Brake Upgrade
    What's a good brake upgrade for a mk2? do mk3 brakes fit in there easy? are they much bigger?
    Looking on the budget side of things.
    No one even think of saying big brembo's n:
    what about small brembo's lol sorry dude im sure you can do vr6 upgrade and go to 5 stud aswell
    mk4 the mods begin for round 2 hahahha
      Going 5 stud would be a bit of work, let alone having to buy a new set of wheels to go with it.
        RayRay has a set of vr6 calipers and that and I have a set of vr6 rims lieing around not doing anything.....................hint, hint, cough, cough
          Don't tempt me Steve.
            Something I was thinking about lately too.
            I want to keep it 4 stud but would like to know what would be best to upgrade from my 239mm fronts.
            280mm sounds like the go, where to get them from and what else is needed ?
            sigpic MK2 GTI G60
              I think it's easier to go from 256mm to 280mm as they have the same hubs and if you're wanting to upgrade you need the later 256/280mm hubs. A lot of the UK mobs do conversion packages but it's obviously more expensive if you need hubs aswell.
              For people like me with 256mm brakes I think it's just larger discs, pads and spacers for the caplipers.
              mk2 GTi 16v
              Corrado G60
                Are your calipers the dual piston type ?
                sigpic MK2 GTI G60
                  So whats involved, hubs, calipers, discs & master cyl. Anything else ?
                  sigpic MK2 GTI G60
                    Gavins got some 256 calipers I think
                      No single piston type.
                      mk2 GTi 16v
                      Corrado G60
                        Hey guys...
                        I'm gonna watch this thread with interest, as I have already upgraded my rear calipers to Mk3, however it must be noted that you have to bleed the brakes with the calipers off, as the mk3 are front-mounted on the disc, so the bleed nipple will be upside-down on the mk2.
                        Now that my rear bias is too strong, I will be looking to upgrade my front brakes as well, probably Mk3 GL, but I'm unsure of the process. I believe aliasmk2 has some experience with brake upgrades, perhaps he would be a good person to talk with?
                        Cheers!
                        JHN
                        Canadian dubs coming to VWwA soon
                          I've done the 280mm conversion. You need 16v hubs, 16v calipers, G60 caliper carriers and the 280 discs. I had to grind my G60 pads down to fit as obviously you want the wider G60 caliper (expensive/hard to get hold of).
                          Also once you go to 280 you can only run some 15's and even my 16" borbets have a tiny spacer to clear the bigger brakes.
                          edited to say does anyone have any brakes pads for the 8v 239 set-up they don't want?
                            You can bolt hub, disk and calipers on from a Mk3. 2L GL are bigger than Mk2.
                            You can go 280mm with either VR6 gear, but you will need new disks, or go 5 stud, 0r Harder to get 280mm Rotors from a Cuprasport, 280mm and 4 stud.
                            Once again, SEAT is the link
                              im doing a 256mm front and rear from a passat gt (everyone in nz buy them and rape them for parts) and also 22mm master cylinder.just make sure you take the whole carier and rear stub axles
