What would be a good suspension setup for a mk2 used for trackdays and hill climbs ect?
Trackday mk2 suspension setup?
What specifically do you mean?
Torsion bars? Damper rates? Camber? Spring rates and heights? Tyre pressures?
All depends on the track and wheather conditions mate.
Is it stock atm?
Cheers,
Wade-1990 Mk2 GTI 5-door with AMK 20vt (260hp @ wheels)
Do you have a budget?
There are plenty of cheap coilover systems on the market which will give you more ability to dial the car in. The more expensive you go the more features/better quality they are going to get.
FOLLOW US ON FACEBOOK
Originally posted by velly_16v_cab View Postmy list would go...
Poly bush the car,
anti roll bars
Good shock and spring set up (cheaper than coil overs)
280mm brakes
semi slick tyres
