has anyone done a 2.0 mk4 engine into a mk1?
AK engine into mk1
I imagine it would be the same as a 1.8t in terms of mounts and that, but others would know better.
My question is why? Mk3 2.0 engines are everywhere and mk1 mounts bolt straight up. You can even fit mk4 heads with a little modification. Does the AK have an aluminum block?77 Mk1 GLS 2 door - That sinking feeling
76 Mk1 Swallowtail 2 door - Replace that BMW & 76 Sweetheart
Originally posted by Browneye View PostI imagine it would be the same as a 1.8t in terms of mounts and that, but others would know better.
Sorry for pitching post but I got a 2e in mine and searching for bit more go what's this bout mk4 heads, 16v?
Sent from my iPhone using Tapatalk1977 2dr golf gls (Gti look a like with 2e convertion
1978 Golf Gti barn find
2013 Amarok Highline daily
2017 Golf wagon wife’s daily
^ At a guess I would think Browneye might be talking about a 2lt cross-flow head from the Mk4 (rather than the counter-flow ones that come as standard on engines like the 2E).Mk3.Mk4.Mk1
My Mk1 Project
Sorry for the confusion. 8v mk4 heads can be put on external water pump blocks but they require welding and machining so that the oil returns line up with the block. Same goes for 20v heads and I assume 16v heads. They both lower the compression to around 8:1 so would need boost or custom pistons.Originally posted by hazards_golf74 View PostThanks is that a 8 v or 16v
Would be easier to put the whole mk4 lump in using off the shelf custom mounts (assuming they're the same as 1.8t blocks). Probably worth a shot. Haven't seen it done personally and would give a mk1 a nice kick up the ass. Not sure how much more than a mk3 2.0 would though.77 Mk1 GLS 2 door - That sinking feeling
