Cheers guys.
@XXX-1.8T - were you the previous owner of the motor before it went into the mk1? if so, do you know what work was done to the head? The guy I bought it from said something had been done in the way of porting but I wasn't sure what.
@Ericcs - I was thinking that it couldn't just be stem seals because of the drastic oil loss but it doesn't smoke after startup except with really hard acceleration from a set of lights. However it does get enough blowby to fill the catch can 1/3 in 1-2 months of regular driving. These could be attributed to stem seals.. since oil would drop seep onto the pistons while idleing and then get burned when taking off... right? same as when it's first turned on, except more oil as it's been seeping longer.
If I can find a low K 1.8 8v for cheap, then I'll just do the swap one day with my uncle who's offered his help for free (makes it far more realistic for me to do a swap rather than servicing the JH).
GeorgeMk1 has a 1.8 8v carbed but it was losing oil when he took it out and he never found out the cause (said it may be rear seal which would get done in the swap anyway). Another lad in vic has a low K 1.8 8v but hasn't replied with price yet. right now it could go either way, unless I find a really low k 1.8 8v for cheap...
 Hope someone gives it the love it deserves
