Hey Guys,
Planning to plumb up my new carter 4070 fuel pump tomorrow.
Just had a little look at my new pump and my rather torn apart mk1 and noticed the following:
The pump runs 8mm (5/16") barbed fittings.
The mk1 is plumbed with 6mm (1/4") OD steel tubing and 6mm (1/4") ID hoses.
I know a few of you run these carters and I was wondering if you did the following:
- squeezed 1/4" ID hose onto the 5/16" barbs?
- swapped the whole system to 5/16" ID (including the steel lines to 5/16" OD)?
- swapped out the carter barbs for 1/4" OD ones?
I reckon the barb on my weber is 5/16" (8mm) too.
Sorry if this sounds a bit dumb, but Ive plumbed air and water, but never fuel!!!
any help would be great!
cheers
j
cheers
j
