Oil pressure is pretty easy dude, the sensor should just screw into the cast piece where your oil filter is (on the top), run the wires through, hook up earth, power, and ignition coilwires to the ignition, then badabing badaboom!
Oil pressure gauge
I've got a Podi one in the two door and I love it. Definitely worth the money (roughly $150 to my door, and that was gauge, sender, wiring harness, and installation guide)
If you want photo's though..
http://www.podi.ca/Pdf/oil_pressure.pdf
VDO Gauges are good kit though, i've got a tonne going into the four door. Period correct as well! They are fairly costly though. Cockpit Vision is the series that suit the Mk1 gauges best if I remember correctly
