Oil cooler repair! Who can help in Sydney?
  • Oil cooler repair! Who can help in Sydney?
    Hi team,
    I've got an external oil cooler in my Mk1 which has sustained damage at some point in time. It's now leaking oil fairly badly and I'd like to get it sorted out.
    Who can do this sort of work in Sydney and how much should I expect to pay? Or could I get a direct replacement? I'm not keen to mess about with different fittings for another one. Any help appreciated! Here's a quick shot of it.
    Thanks.
    I can sell you one !
      A direct replacement? I'm all ears if so. More details please.
        Is it the genuine GTI style one? If so they're same as superbug and readily available.
        7? MK1 Caddy
        79 B1 Passat Dasher Project
        12 Amarok
          I'm really not sure. I'd need to compare them side by side. From a quick Google they look quite similar. I might have to do some measurements.
            The one you picture is a std GTI MK 1 oil cooler, identical to the aircooled engine version other than they stick a length of foam seal tape down the side that goes up against the radiator.( minimise air bleed between the two coolers ) Changed my last one back in about 1988.
            Available from VW Classic parts germany or heratige vw in UK plus many other establishments.. start phoning !!
            Lots of MK 1 Scirocco's...
            Cheers,
            Grant...
              I appreciate the help, blokes. Thanks a lot. I'll track down a new one.
                Engine Oil Cooler for VW Golf 76-83 | eBay
                This one is free delivery and i can bring it back in my suitcase mate
                76 Mk1 4DR SOLD
                01 B5.5 Passat Wagon SOLD
                84 Mk1 GTI
                  Just go to any VW shop and buy a cooler for a Bug,most shops would have a new one on the shelf. Pete
                  Widebody Cayman S Turbo, 83 ur Quattro
                  2000 996 C4 cab,12 Scirocco R OEM+ STG2+
                  72 914 (3.2S boxster pwr), 92 G60 Corrado
                  76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
                    know anywhere in sydney?? north shore
                    76 Mk1 4DR SOLD
                    84 Mk1 GTI
