Hey guy I'm just in a predicament at the moment. I've got a 4speed diesel gear box and I just brought a 1.8l 8 vale engine block, im about to replace the clutch before Assembling them together, is there a specific clutch I need to install or just a standard NA clutch.
Mk1 golf help
It's a 1980 GLD, ive taken out the diesel motor and replacing it with a 1.8l 8v motor. I'm trying to reuse some parts which can also adapt with both motors. It's not going to be a everyday car that ill be driving in and I'm aware of the final gear ratio on a 4 speed box.
What are your thoughts. Should I Just leave the 4 speed boxMK1, 1976 golfLS, 4 door (SOLD! Will be missed)
MK1, 1980 golfGLD, 4 door (1.8l, 8v, 5 speed)
unless you do lots of hwy kms,the 4 speed will do fine, imo.
I believe you are getting it wrong. A diesel engine revs a lot lower than a petrol. Therefore the gearing in a diesel gearbox (ie final drive ratio) is much taller (smaller numerically). So rather than screaming its head off the revs will be lower for a given speed than for a "petrol" gear box. This would make highway cruising easy so long as the engine has the torque to pull it. A 1.8 should handle it quite well.2001 Bora 4 Motion Sport now used by number two son
Thanks a lot for that vital
Information. I was stressing out couldn't decided on keeping my gearbox or going out and buying one which Now isn't necessary!youve all made my first step easier thanks again
Originally posted by Bora Sport View PostI believe you are getting it wrong. A diesel engine revs a lot lower than a petrol. Therefore the gearing in a diesel gearbox (ie final drive ratio) is much taller (smaller numerically). So rather than screaming its head off the revs will be lower for a given speed than for a "petrol" gear box. This would make highway cruising easy so long as the engine has the torque to pull it. A 1.8 should handle it quite well.
Originally posted by Stanton View PostYou are wrong.Do the research.I couldn't be bothered seeing you don't want to agree.
Consider that in my old LS, 1.6 petrol, the standard 4 speed had me doing 4200rpm at 120km/h! Woooo!'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
4 speed gear box will fit fine, but you will have problems with trying to fit 5 speed gearbox without having to do some modifications to the gearbox mount as 5 speed is 5-10 cm to long....also unless you are good with the electrics dont do the engine conversion as you might strugle to find someone to do it for you, n thats y i sold my mk1shame.....
