Hi All
I have been trying to work out why my heated rear window does not work
I have checked the fuse and switch which seem to be ok. I put a 12v circuit testing light across the fuse however there wasno power... it this normal when the demister switch is turned on?
Tried to read the Haynes manual circuit diagrams to determine wire colours etc, and see where the issues could be but no luck so far
What could it be?
Has anyone repaired theirs in the past? Any tricks to be aware of?
I thought if the switch was on there should be power at the fuse. I have also checked to see if there is power at the rear window but nothing...
Thanks for any advice
What could it be?
