Cylinder Hone size
  • Cylinder Hone size
    Is a 4-1/8" (105mm) Flex-hone appropriate for a stock 1.8 KR (87.5mm bore I believe)?
    From my searching on the web I found that the maximum Hone size is 1/2" larger than the bore, so I may have been a little optimistic purchasing one that is 1/8" over this..
    What is the best amount the hone should be larger than the bore?
    Henry
    Successful trades with: dubdan; vwgolf; Jace; Preen59; RedMk2Gti
    I'm pretty sure the KR bore is about 81mm... which makes your 105mm hone 24mm bigger.
    i'm not sure if thats too big. I would have said go ahead if the bore was actually 87.5mm, but pretty sure its about 81mm. hope that helps.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
      I just got home and roughly measured it then, and you're right its closed to 81mm.. Not a problem, I can return the hone, But what size do I buy?
        Flexi hone I use is about 3 3/4 " Dia, red tell tale for grit grade ( from a rusty memory ) Use light or honing oil ( NOT kero or any solvent based lube ) Make sure you THOROUGHLY clean the block after, should be able to wipe the bore with a clean lint free rag and have no residue whatsoever on it.
        HTH
        Lots of MK 1 Scirocco's...
        Cheers,
        Grant...
          Good to hear you're onto major stuff Henry!
            Cheers guys, and yep it's good to be finding time to get my hands dirty!
