After market EFI
  • #16
    umm.. don't think so dado, I do believ that was a factory 16V. It's been destroked to run in 1600cc class. custom length rods, and pistons.
    Really?...Hmm some one told me it was an 8v bottom end.
    MK1 GLS 3door
    A4 B7 2.0T
    • #17
      Originally posted by GRN_VAGN View Post
      just reading on how it relates to the golf and if possible.
      turbo or supercharged 8V would be pretty fun
      Where are you finding your info?? I'm looking at supercharging my 1800 for a bit of fun since everyone else turbos theres wouldn't mine some more info on the EFI
      Mk1 76 donor car
      Mk1 GTS 83 SA import,
      MK1 76 project
      • #18
        Originally posted by ozgti View Post
        Can you put a 16v head on an 8v block?
        You can, but the resulting compression is very low and more suited to a turbo/SC application
        The yanks fit 16v heads to their 8v ABA engines, but they use ABF pistons in the process to make a half-arsed "ABF" engine - or they do it to make a 16vT.
        Aftermarket EFI is a waste of time & money unless you're modifying (or planning to modify) your stock engine beyond the reach of the standard ECU - or if you have an engine to transplant which came with no electrics
        • #19
          My olmand has a 16v head with 16v bottom end (Bloke is PL code from a US passat im pretty sure) engine is destroked with custom crank, rods etc...
          In regards to after market ECU. Well Motec if you have big dollars, then there is Autronic etc. This mega-squirt stuff seems awsome for those keen to learn and tune.
          • #20
            i take it the Digifant and Digifant 2 is the VW efi system for golfs?
            DO they have the injectors in manifold, and could one be setup to run on a Mk1 engine?
            Pretty interesting read anyway,
            <space for rent>
            • #21
              All this talk might as well be another language to me ... ahahaha O.o
              - Brown U.S import 81 cabby
              - 88 Honda crx b18cr
              • #22
                From the late 80's till 92, yes it was, in MK2 Golfs (feel free to correct me).
                You've also got Kjet/CIS (mechanical injection) in that time period/era too for Golfs too.
                The uber DIGIFANT thread
                The Uber CIS thread....
                Go crazy
                HAHAHA
                • #23
                  Go crazy
                  WOW!! :O
                  Thanks, spent 2 hours reading
                  <space for rent>
