Some people rave about the ABF 16V, but I would doubt that on the road you would notice the extra 11hp and 11ft.lbs of torque?
1.8 KR 16V (US spec)
123hp @ 5800rpm
120ft.lbs @ 4250rpm
1.8 16V (Euro)
139hp @ 6100rpm
124ft.bs @ 4600
ABF 2.0 16V
150hp @ 6000rpm
135ft.lbs
Many of the KR 16v you would find in Australia would be US spec and would require Euro cams to bump the power up to 139hp.
Difference between ABF 16V and 9A 16V:
digifant 3.0, Rods are 15mm longer(159 vs. 144), block is 16mm taller(236mm vs. 220).
Different cams, narrower intake ports on ABF/9A than KR/PL, better exhaust ports on ABF/9A than KR/PL.
ABF uses 35 mm long valve guides, KR/PL uses 38 mm.
ABF uses different inlet and exhaust valves (95,5 and 97,95 mm long) than KR/PL (95,5 and 98,2 mm long).
ABF uses VR6 valve spring retainers, Longer cambelt for the 16.5mm higher block. ABF uses a welded tube exhaust manifold, KR/PL uses cast exhaust manifold
123hp @ 5800rpm
120ft.lbs @ 4250rpm
1.8 16V (Euro)
139hp @ 6100rpm
124ft.bs @ 4600
ABF 2.0 16V
150hp @ 6000rpm
135ft.lbs
