Oil catch can?
  • Oil catch can?
    i found an oil catch can in the shed that i bought for my last car that i never used.... how would one intsall on on a stock 1.6 mk1?
    might as well put it to use
    Just plumb it straight off your rocker cover breather & mount the the canister where ever you feel the need too!
    Easy as!
    I had just mounted my "powerade" bottle with a breather/filter straight off the clutch cable & plumbed it on with some food processing reinforced hose.
    Worked a treat
    Then relocated the whole lot with a bit more stronger moroso billet bottle & breather. Same type of hosing though
      7? MK1 Caddy
      79 B1 Passat Dasher Project
      12 Amarok
        Needs to plumb back from the catch can to the air filter on the air intake for it to be legal though.
        MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
        "Fit the gearbox ya bum." Loon - best post ever!
          I was thinking about adding one on the 16v, but was worried (which may well be unfounded) that it will affect the vacuum readings on the ECU.
            Only if you vent to atmosphere. Should be OK if you keep it closed circuit.
            Pete
            7? MK1 Caddy
            12 Amarok
              Not on my car!
              Its pre 6/76! No emission required! hahaha
              I do it on all my cars except for the VN.
              With it plumbed back it can also oil up your intakes & throttles, especially on K-jet cars, so thats why I route it to a catch can & block up the intake so it only gets nice clean filtered air & not filthy oil vapours
                so if you're not plumbing it back you just run from the rocker cover to the can then the can to atmosphere, too easy.
                cant see the pics at the moment due to work blocking photobucket.
