to check that it's not the thermo switch, touch the 2 connections to the switch together. If it has a connecter, use a piece of wire or paperclip to short it. If your fan is ok, it should fire up when you short the circuit.
Don't worry about blowing anything up - thermo switch is just a switch so by bypassing it, you're just manually switching the circuit!
good luck
Steve-o
good luck
Steve-o
