rocker cover gasket troubles
  • rocker cover gasket troubles
    i have got a early mk2 GTi engine K-jet (EV) i bought a rubber gasket and when i changed it, the mounting holes were to small for the gasket to sit flush, and oil pissed out everywhere, i though i was going to have an engine fire.... ... any ideas??? have i got the wrong gasket??
    When I bought a rubber rocker gasket I found that the studs on the head had shoulders on them, so that the gasket wouldn't fit. I think the dealer should have supplied new studs when he sold me the gasket.
    Anyway, I drilled out the holes to the size that fitted, and played safe with black silicone, and the thing doesn't leak. Think that getting the correct studs would be a better idea than drilling a brand new expensive gasket.
      Use an early type cork gasket or get the later studs, like on a Mk3.
        that sounds right. i though about drilling them bigger.. i cant use the car as it is now so ill drill them bigger.. and i was looking for a cork 1 but no1 had any.. ive got gasket glue stuff. ill use that... stuff like this makes me want to get a new engine...
          Techtonics ( amongst other suppliers) does an upgrade kit for the cork gaskets,
          1 Piece rubber gasket and the correct studs for $20 US. ( part # 198.163 )
          good people , little bit expensive ...http://www.techtonicstuning.com/
          Did this on my last 1.8 rebuild ( 3 1/2 years ago) and it still doesnt leak. also changed to the rubber sump gasket with windage tray , all good stuff..
          Lots of MK 1 Scirocco's...
          Cheers,
          Grant...
            Old trick
            But it works When I was an apprentice I learned to smear cork gaskets with petroleum jelly (Vaseline) and let them stand for a while.
            This:
            * softens the surface and protects against initial shrinkage
            * allows them to stick to the surface of one of the components to be fitted
            *Lets you slide the gasket to get it exactly in place
            Unlike grease, petroleum jelly dissolves completely in hot oil and causes no residue.
            If I can't get a surface absolutely clean and free of indents, I smear a very light coat of silicone over the gasket. Silicone's great stuff as long as you use the absolute minimum necessary to do the job. I cooling systems too much will block the radiator core over time, and the last thing that you want is a chunk of it getting stuck in a crankshaft oil way
              i have untold new cork gaskets. $5 each to you blokes
                good price Loon
                I bought a couple off EBay UK for about $20 delivered
                Always handy to have a few extra laying around
                  well i have to pull the rubber 1 off, so IF its f#$%e*d ill PM you for 1..
                    Err what about just pulling the studs and replacing with 6mm bolts?
                    c
                    It's been a while...
                      i used gasket glue so if it was glued on and i broke it trying to pull it off. that is what i meant.... ok wat i did was i just punched the studs out of the gasket and now its sits fine.. but the exhaust manifold was covered in oil so i have to slowly warm it up...
