I'm fitting an 8v Kjet to my Mk1, but don't have a 'tachometric relay' can I just use normal relay?
I have a couple of 30A fused relays lying around, but they only have four pins (missing earth). Will these do?
From my understanding the pins should be (taken from www.diagnostic-assistance.co.uk/mech_inj.htm):
30 - Positive from battery
31 - Earth
1 or 31b - Coil negative
15 - Switched ignition on voltage (from coil)
87 - Out let to fuel pump
What I propose with the relay I have:
87 - Positive to pump
85 - Switched ignition on voltage (from coil)
86 - Coil negative
Will that work?
31 - Earth
86 - Coil negative
Will that work?
