Have just pulled out all the wiring in the mk1 76 3dr GLS with the 1.6 getting it ready for full strip and body work. The wiring is pretty messy and was wondering if there is anywhere i could buy a new complete one or if theres places that will take the old one and refurbish it. If not is there anywhere that sells the plugs that are throughout the whole loom, especially around the fuse box area? worst case i will remake one. Cheers.
Any mk1 wiring upgrade options?
As an upgrade ( you quote in the header ) find a late model cabrio that is being wrecked and replace your whole harness with the one from the cabrio, The relay plate is miles better and still fits the early Mk1 slot.
To do the existing wiring you need to re use almost all of the terminal end blocks, as these are mostly NLA these days.
How do I know ? I am constructing a complete replacement harness for Lukes tarmac rally car, fortunately he has a good head start by purchasing a lot of the factory connector blocks and relay plate a long time back when the stuff was available, so we are on a winner there.
Already I have run into a supply issue trying to get some of the correct size and coloured wiring. 4 mm2 red with black trace ( starter circuit ) is unavailble unless I have it manufactured ( yeah, 2500 metres min order )
The correct terminals are available for all the blocks, however this does take a lot of search time locating them.
Good luck with what your choice is .Lots of MK 1 Scirocco's...
Cheers,
Grant...
Originally posted by roccodingo View PostAlready I have run into a supply issue trying to get some of the correct size and coloured wiring. 4 mm2 red with black trace
A good source for cables is a T3. They were built up until '92 and the cables are longer and usually clean.
If you need something specific I have a lot of old stuff that was taken from Golfs many years ago.
If you need something specific I have a lot of old stuff that was taken from Golfs many years ago.Lots of MK 1 Scirocco's...
Cheers,
Grant...
I have a 1980 Caddy that I'm rebuilding and I would like to install a clean, simple, new wiring harness to replace the original. Has anyone done this? What are my options? I'm having a hard time finding any information online... tellculvers com survey taco bell breakfast hoursLast edited by gehlotsur; 05-10-2022, 06:02 PM.
I have a 1998 Seat Cupra that I'm going to transfer all the wiring into my 78 Mk1. Got to be better than the original wiring and I like the idea of having new type connections.1978 MK1 2.0 16v http://www.vwwatercooled.com.au/foru...-46488-70.html
