Can anyone offer some guidance please?
My daughter has a 2009 2.0 TDI manual, which I think makes it an early Mk6, and in the past we have had issue with the turbo diaphram. This was replaced about 18 months - 2 years ago and all was going well until recently when the turbo light on the dash started coming on again. This happened to coincide with a service so I asked them to check it out but there was no fault code registered?
Now we have an engine light, only yellow at this stage, and the turbo light on. Most of the time the turbo light can be reset by turning the car off waiting a couple of minutes and then staring again.
At the last service the tech said the EGR valve needed to be replaced and that if it wasnt done it could lead to reliabilty issues.
Is this likely to be the cause of problems? Car has 120K on it so should only be just run in.
What direction to go in?
