Odd loss of power Mk3 Tdi
  • #31
    Originally posted by G60ING View Post
    If you want help trouble shooting TDI engines then you should visit the TDIclub forums. More knowledge than you can shake a stick at.
    Thanks for that.
    TDI applies to both PD and CR doesn't it?
    • #32
      TDI applies to just about all computer controlled VW/Audi diesels made after mid 1995 in Europe and 1996 in the USA. The mk3 jetta/golf could be an idi but if it has and AHU or 1Z engine code it's a TDI. It's a tdi with and injector pump which the CR and PD both don't have.
      • #33
        Hello sparkie, Just so we all know the right facts can you say what year model and what engine code your Mk3 is.
        • #34
          Sparkies car has a 1z
          '98 Mk3 Cabriolet 2.0 8V
          '99 A4 Quattro 1.8T
          • #35
            I think all Oz-delivered-fully-imported-by-VW Mk3s had 1z Tdi engines, there were Idis in the UK at the same time, and a few may have crept over here.
            Just a final progress report, on the suggestion above I have checked, and replaced all the rubber hoses with silicon ones from Pirtek, and the turbo is behaving itself fine. 300km since Friday afternoon, in 110kmh traffic on a 29 degree day to Brisbane and back this morning confirms it's running well again
            Mk3 Golf Tdi about to sell
            Mk 1 Golf GLD somewhere in a paddock!
            Mk1 Golf Cabriolet
            MK2 Golf Turbo diesel engine and 5 sp gearbox
            • #36
              Good to hear. Did you manage to isolate the problem?
              '99 A4 Quattro 1.8T
              • #37
                Bugger it, no I didn't. Running up a very steep hill tonight, engine cool, not been used for 4 hours, managed to get into 2nd gear, the hill was so steep I had to get right up towards 4000 rpm to gearchange, still, all good in 2nd gear for a few seconds turbo whistling away, and suddenly the torque drops out and I have to quickly drop down to 1st to get up. Still it's much improved. I bought another 3 metres of 4mm silicon hose today, I'll change all the rest of the hoses over the weekend. if that doesn't work I'm changing the N75 solenoid/valve
                Mk1 Golf Cabriolet
                • #38
                  Finally sorted it, and all it was, was the N75 valve!
                  I went through this trouble-shooting list:
                  How to troubleshoot low power on an A3/B4 engine - TDIClub Forums
                  I checked everything I could without an OBD tool and without a pressure gauge. I had replaced all the vacuum hoses between the turbo-charger, the N75 valve (on the left-hand guard on a Golf Mk 3) and the ECU a few months ago. The next step was going to be checking the intake manifold and turbo charger, but then I saw further down in the discussion a simple way to test the N75 valve, and so i did the test, and it was clearly at fault. New N75 valve from UK Ebay (but posted from Estonia!!) and the car is burning tyres again! Phew!
                  Mk1 Golf Cabriolet
                  • #39
                    Hurrah!
                    '99 A4 Quattro 1.8T
                    • #40
                      I told You
                      Glad it's sorted.
