Engine number help
  • Engine number help
    I'm new to the tdi world, can someone tell me where to find the engine number on the 2009 125tdi Passat?
    Many thanks
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
    Many thanks
    Pretty sure it tells you in the manual but its too cold to go and look ATM
      The engine number is stamped on the engine block near the gearbox but the engines these days are so cram packed with crap that you only see it when you strip down the motor!....There is the front page in your owners manual should have a square white label stuck in there, also the same label in the boot under the floor mat..and it can also be seen on the cambelt cover on a small white sticker..should be something like BMR, BMN, etc....VDUB...(Hillbilly...lol...your country flag is NZ and your in Brizzy and its too cold!, wimp!)
      BRISBANE / GOLD COAST
        Been here 11 years now so am acclimatised At least my arthritis is. LOL Glad someone noticed the flag Finally
