Hi all,
Today i received and installed my modshack intake on my MkV (see below).
Installation was relatively simple but required some minor modding to fit the TDI. The modshack is not technically designed for TDI's and as such, does not include the vacuum connector that is on the stock system. To overcome this, I drilled and installed a vacuum connector (see below). It goes to the solenoid valve block so i cant tell what valve it goes to. Can anyone advise as to what this does? Do you think that it is ok how it is plumbed or should i use an elbow rather than a T piece connector? It was the only connector i had at the time...
The car seems to breathe much easier and feels a bit snappier. My only gripe would be the occasional stutter at low speed. I suspect it is due to the possibility of sucking in hot engine air as, unlike the stock intake, it is not plumbed into the front bumper (see below).
I haven't had a look at how Greg has done it yet but i plan on buying an aluminium tube and make my own plumbing (see below). Its actually for flues in fireplaces but it is essentially a thin aluminium tube that i hope to cut and bang so that the pod only draws in cold air from the front grill. Any thoughts on this?
