Originally posted by thealienfromuranus
View Post
Did my EGR delete!
where do you get these hybrids?VW: it aint just a car, its a way of life
Talk to your mates at Darkside Developments!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
yeh probably is illegal, but its for the longevity of the engine. I wouldn't recommend doing it to a car in warranty!Originally posted by getjet View PostIs it *cough*illegal*cough* to remove the EGR? How do dealers handle it if you get a dealer service (obviously out of warranty)?
---------- Post added at 12:06 AM ---------- Previous post was at 12:06 AM ----------
I will when the time comes.Originally posted by Greg Roles View PostTalk to your mates at Darkside Developments!
reply to my PM ya slacker!VW: it aint just a car, its a way of life
Don't even worry about the hybrids. The EGT's and EMPs they produce are ****. Unless you want to pull the head off an ddo some major port work and get a cam in there to get the EGT's back down you are better off going the 17562008 VW Polo TDi
GIAC | REMSA | PD160 | DECAT | MUFFLERECTOMY | ECS | SUPERPRO | PXL KIWI WIFI | 312mm BRAKES | OZ RACING | KUMHO V70A
To Buy: VNT 17/22 or K3 Turbo | R783 Nozzles | Intercooler | Water meth kit.
My inlet mani gasket was a metal one, which is re-useableOriginally posted by getjet View PostJust purchased the required parts to delete the EGR and cooler from my Jetta (darkside kit). Plan to clean the intake manifold and ASV while I'm at it. I shouldn't need any gaskets if I'm careful, correct?
but that was on the Polo TDI which is an 8v. Yours may be different!
If you have the rubber oring style gasket in yours, you can put Loctite Maxi Gray on the old oring gasket, but it is better to replace it with the new one (not expensive).Originally posted by getjet View PostJust purchased the required parts to delete the EGR and cooler from my Jetta (darkside kit). Plan to clean the intake manifold and ASV while I'm at it. I shouldn't need any gaskets if I'm careful, correct?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
As Miro suggests new gaskets are stupidly cheap from VW, my GT TDI inlet one between the mani and head was only $8!!
That said, if an o-ring looks fine, I just reuse it, so long as it is still round in cross section and sticks out from the face, when they get compressed level they will no longer seal and need to be replaced2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
