what about 2.5?
Did my EGR delete!
finally done it. cant see what all the fuss is though. cant feel any difference at all. it is a good thought though that im no longer sucking up rubbish. do wonder if its normal for egr to have so much oil in it and where does it come from? and also what is the purpose of the butterfly on the egr valve? i noticed it never moves whatever the revs are.
Originally posted by jfoldbar View Postfinally done it. cant see what all the fuss is though. cant feel any difference at all. it is a good thought though that im no longer sucking up rubbish. do wonder if its normal for egr to have so much oil in it and where does it come from? and also what is the purpose of the butterfly on the egr valve? i noticed it never moves whatever the revs are.VW: it aint just a car, its a way of life
Originally posted by jfoldbar View Postdo wonder if its normal for egr to have so much oil in it and where does it come from? and also what is the purpose of the butterfly on the egr valve? i noticed it never moves whatever the revs are.
Enjoy.Golf GT Sport TDI
Originally posted by GoLfMan View Postbutterfly is there as a shut of valve for the engine I believe.
It is absolutely necessary to do a regen if you have a DPF - GT TDI/Passat in MKV or all MK6 TDI's.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
i got thinking, when i done delete, should i have disconnected vacuum hoses from it so butterfly cant work. if it moves after delete engine cant get any air and will choke. what should i do with hoses when i take them off. since they still have vacuum they could suck up dirt if they are just hanging around.
Originally posted by jfoldbar View Posti got thinking, when i done delete, should i have disconnected vacuum hoses from it so butterfly cant work. if it moves after delete engine cant get any air and will choke. what should i do with hoses when i take them off. since they still have vacuum they could suck up dirt if they are just hanging around.
Originally posted by GoLfMan View Postsure does! Big fan of the new driving experience
however my only gripe is by getting rid of the flap, shut off is a lumpy affair, scared the crap out of me when I first turned it off, but then I worked it out and it was all ok2008 VW Polo TDi
GIAC | REMSA | PD160 | DECAT | MUFFLERECTOMY | ECS | SUPERPRO | PXL KIWI WIFI | 312mm BRAKES | OZ RACING | KUMHO V70A
To Buy: VNT 17/22 or K3 Turbo | R783 Nozzles | Intercooler | Water meth kit.
Originally posted by Evaded Motorsport View PostReally? I found it to be about the same as normal but mine is fairly rough anyway. I'm getting no bites on selling it so I'm just about to order the diesel Geek turbo kit and a FMIC.VW: it aint just a car, its a way of life
Nah, going the 1756VK or the 2056VK 17/22 has issues with EMP. Budgeted the next stage of the build. $8,200 give or take lol.2008 VW Polo TDi
boraparts.com had the 1756vk brand new for $900 or something. Dam cheap for an upgrade!VW: it aint just a car, its a way of life
Originally posted by thealienfromuranus View PostDoesnt a 1756vk require a custom manifold to fit?VW: it aint just a car, its a way of life
1756VK Requires a custom manifold to fit, the 1749VB is a single piece item. the 1749VB off the PD150 can make up to 200hp the 1756VK can make up to 230hp.2008 VW Polo TDi
