G-8VXWWTRHPN Mk2 1.6 TD engine into Mk1 Cabriolet - VWWatercooled Australia
  • Mk2 1.6 TD engine into Mk1 Cabriolet
    Hi everyone, just starting to put together the above conversion. I have a 1.6 TD and 5 speed gearbox from a Mk2 Golf, but I have no idea of the history of the engine except that 'it's a go-er", and apart from basic car maintenance I am a bit of a newbie. What would anyone recommend I do to the engine in the way of servicing and maintenance before I drop it into the cabriolet? Also, anyone got any recommendation about what radiator to put in - will the Mk1 petrol in there already be fine, it's got air con!!!! is that an issue? I need an alternator and starter for the engine, are they the same as a Mk1 diesel or petrol engine? There are a few (only a few thankfully) electrical connections on the Mk2 engine, what are they? I reckon the electrical connections using the petrol loom are going to be the hardest. There's one on the water system (temperature sender?) one on the injector pump, etc - maybe pictures would help. The clutch is still on the engine, and the gearbox is lying around the corner of the shed, what should I do to either while I can easily get to them? Anything else while the engine is on the lift? Should I bolt up the gearbox to the engine before dropping it into the car?? Should I paint the engine or any covers? Any help appreciated, would this better more suitable in the Mk1 forum?
    Mk3 Golf Tdi about to sell
    Mk 1 Golf GLD somewhere in a paddock!
    Mk1 Golf Cabriolet
    MK2 Golf Turbo diesel engine and 5 sp gearbox
    Hey mate,
    The injector pump is pretty important - if it has been stored with the fuel lines plugged up tight then its probably OK but if not it might give you problems when you go to start the engine.
    I would put a set of new glow plugs in it for the sake of $80 from a local supplier it might save you an afternoon of headaches wit that "first start".
    I would also remove the oil lines from the turbo, and clean them and make sure they are OK. I would probably also pull the sump off and ensure that its pretty clean in there - that the old engine oil hasnt gunked up etc. If it has, i'd recommend putting hte engine on a stand (if its not already) and doing a full strip down/clean/reassemble. My TD cabrio thread in the mk1 section has some pics of hte work i've had to do it that regard.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
      Thanks mate, jut what I needed to start off. It's on a stand, so I'll start cleaning and stripping down
      Mk1 Golf Cabriolet
