I believe they are even smaller than the GTI brakes. I replaced the rears while I was at it with new standard rotors however I switched to ceramic pads.
I believe that the GT has the same size rotors as the GTI (312mm).
The rest have slightly smaller (288mm).
Correct. Which explains why he says its such a difference, going from 288mm to 345mm. I'll be fitting my Golf R brakes soon to my GT so will let you know if I feel any difference going from 312mm to 345mm.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
