VW Diesel PD Piezo Injector. (also for non piezo injectors)
I've heard overall that the loom is simply replaced as the oil hardened plugs are real easy to break, heck I sure did break my old ones when putting in the new Audi loom!
Last Thursday on Hume, just before Wallan exit "Engine failure", no warning whatsoever, no power steering, no brakes, managed to pull over without incident.
car: Passat wagon, 125 kW, 4 years 2 months old
odo: 84,220
Towed to Wallan, RACV guy thought I'd run out of fuel.
Towed to Bayford VW in Cooper St, Epping next morning. Received call that care had been received, but busy and long weekend.
Received call Wednesday morning, injectors replaced (incl. loom), under warranty. Only charge was for performing the diagnostic ($130), happy with that. Had faulty park brake switch replaced as well but had to pay for that.
Picked up car today, cleaned inside and outside, drives like a dream.
Very happy with the customer service, will take my car there for the servicing in the future.
Let's hope it's not going to happen again.
Michael
MY08 125 kW TDI Wagon
PE Black, Sunroof, iPod
MY09 CR TDI Eos 6-speed manual
Candy White, black leather, Sports suspension with 18" Chicagos
I have 03G 130 073M injectors ( can just read on the bottom right of pic ), so it seems sooner or later my TDI will probably conk out...
I think you will be OK. When mine died the reason quoted was "Carried out TPI. Found the current part number on the injectors is incorrect". They were replaced with part number VW03G130073TX which is what you have already. See also JAZD 's 09/02/12 post last line.
Was advised that VW are now covering injectors and harness under warranty for 7 years in lieu of the standard 3 years.
Granite Passat sedan TDI (125kw), DSG, beige leather
Candy White Polo 6R, 66TDI, DSG, no options
Refurb is probably a great thing, as I believe they simply fit a second o-ring to stop oil getting into the piezo stack, where the standard injector has only one. My vote is still oil quality, heat, and oil ingress into the piezo stack, but I reckon only Siemens themselves know, and keep it under wraps.
It’s not the loom that causes the failure; the short is internal to the unit injector. The fault codes logged will not indicate which injector it is, and you unplug each injector one by one, trying to start the engine between (on three), when you have the right one unplugged the engine starts (and runs rough). Usually the harness is damaged during the process and it’s policy to replace it, at $130ish it pays to do it even if undamaged while you’re there and the cover is off as apposed to coming back in later.
If it was the loom, the short would still exist after the injector is unplugged
Only on the Bosch /103 system Harlie, the Siemens 125 system is a situation of all 4 are series, as opposed to parallel, where it can't distinguish betwwen them. It won't run on 3 as far as I can tell, was always my plan if one went on the side of the road!
---------- Post added at 03:19 PM ---------- Previous post was at 03:18 PM ----------
Only on the Bosch /103 system Harlie, the Siemens 125 system is a situation of all 4 are series, as opposed to parallel, where it can't distinguish betwwen them. It won't run on 3 as far as I can tell, was always my plan if one went on the side of the road![COLOR="Silver"]
Greg, this is how I'm told they are finding the faulty injector on the 125 - both independent VW shops that I spoke to in BNE gave me the same method - cover off, unplug injector 1 by 1 and when you have the right 1 it will start and run. As you know I have the 103, and when it stopped it would restart (only run for 30 sec), so this method was no good for the my 103 because when the faults were cleared it was happy for about 30 mins - when I mentioned to Mike (P & P) that mine started it was met with puzzled look and "oh crap, not seen that before, that makes it interesting". At the time all of the failures he had seen were 125.
What's in series? How can an ECU control individual injectors with an anologue signal if the signal lines are in series? I could be wrong...
