Sorry to dig up an old thread. How have the Provents been going? Im considering putting one on my Passat 125 TDI.
Provent / catchcan fitment kits.
I'm about to set up two in series in the Yeti, so my vote is "essential".2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
By then it's too late to bother mate. Oil ash buildup is what kills the DPF and the PCV vapour / EGR soot builds up in the manifold, ports and bakes onto intake valves. Using a inlet "sea foam" type flush, that is one specific to diesels, is one option, but in my mind just ends up in your DPF. No way a genuine Provent 200 in the stock PCV system could be seen as a warranty killer, for the manufacturer Mann and Hummell build a vast majority of the plastic air boxes, inlet, manifold and filtration systems on euro cars, and apart from sucking in dirty air via an open drain tap, I can't think of a way it could cause harm. It is CE marked etc etc, just watch out for the China fakes, they DO cause problems.
Still your call, given what I'm about to do to the Yetis DPF system, I think my local dealer won't be too worried about the Provents!2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Nope, it's total km buildup. Short trips can kill DP lifespan, oil / EGR buildup is a whole separate issue. It's basically like cholesterol for your intake, especially the inlet runners and ports.Originally posted by Ryeman View PostMine's never used for trips less than 30kms - almost all 100+.
Is that relevant to egr contaminant quantity and buildup?Last edited by Greg Roles; 25-02-2015, 06:40 PM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
A fun Sat arvo project, done and working. See my tinker thread for details.Originally posted by Ryeman View PostWhere will you mount 2?.
I still need to put one on the Caddy.. Hoping the water/methanol kit helps to clean the inlet, though.
Hi Greg, I have never owned a passenger diesel powered car and have ticked Diesel power for my next car. Been driving Diesels in the VW Golf 7, Tiguan, Skoda Octavia, Mazda CX5 and Ford Mondeo TDI Wagon and some others.Originally posted by Greg Roles View PostBy then it's too late to bother mate. Oil ash buildup is what kills the DPF and the PCV vapour / EGR soot builds up in the manifold, ports and bakes onto intake valves. Using a inlet "sea foam" type flush, that is one specific to diesels, is one option, but in my mind just ends up in your DPF. No way a genuine Provent 200 in the stock PCV system could be seen as a warranty killer, for the manufacturer Mann and Hummell build a vast majority of the plastic air boxes, inlet, manifold and filtration systems on euro cars, and apart from sucking in dirty air via an open drain tap, I can't think of a way it could cause harm. It is CE marked etc etc, just watch out for the China fakes, they DO cause problems.
So any Diesel on my list and in general would benefit from a Provent?
I previously owned a highly modified WRX and made my own CatchCan for it with self draining to the sump.
So the Provent operates on the same principal of removing excess oil in the engine ventilation system?Last edited by Polo GTEye N9; 09-03-2015, 09:22 PM.
