Originally posted by cogdoc
View Post
Clean up
Nope, I WISH it was so easy, but I've had to add water meth to combat the potential hgher temps without it, and am still working out how to simulate the egr mechanisms so the car doesn't go into limp mode once it's all removed. Can be done, but it's not straight forward. There's also the potential increased NO emissions to consider, which in my case shouldn't get any worse.Originally posted by Buller_Scott View Postawww crap.
im also looking into something like this for a short term fix as my lovely Seat intake is showing signs of warping due to heat. this looks good:
p.s. i presume the egr removal is part of the dpf delete software? how would you have done it if you had to do it manually/ without software?2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
this page is too inspirational: http://afepower.com/shop/application....php?brandID=1
that's it. im getting my hands dirty.
Originally posted by Buller_Scott View Postthis page is too inspirational: http://afepower.com/shop/application....php?brandID=1
Mate i am selling one if you have a Jetta or Golf 2.0TDI.... check the for sale section.
After following these instructions, this is what it should look like:Originally posted by Transporter View PostHere is the minimum what I would do:
Before parking in the garage;
Fill up the tank and put good quality diesel additive to protect from the algae.
Block the inlet and exhaust so no moisture can get in.
Jack the car up and put it on the stands so the wheels are not touching the ground.
Connect the C-Tek battery charger to the battery (without disconnecting the battery). Unless the battery is Optima or similar in design (for starting the vehicle after lets say 6 months).
MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
Hey Greg, how did you go with that blue silicone hose for provent? Did you get rid off any elbows?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Sharkie View PostI've got your Tig as $41890 with your options and the 147 at $42990 ..... but more importantly and something thats not mentioned often ....
The TDI Tig has a DPF, yes? .... and that is not suited at all to sustained city driving ..... so add the cost of replacing that (and its not covered under warranty) frequently ..... and its expensive ....
Our Touareg has the DPF and driven in the city, so far it is fine I check the particle loading and don't expect it to be a problem (should easily pass 200,000km)
Sharkie, if you remember; what was your average fuel consumption before chipping?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Yeah I wouldn't go larger than 3" as well. Our Touareg 6 cyl TDI is 2.5".
im going 3" when i go a GT2260vk
