has this ever happened to u???
  • #16
    Definately blow by. Have seen this many times over the years.
    When I drove my US caddy ute down from Sydney and used 14.5 litres of oil on the way (!) I had a catch bottle setup to prevent tis exact problem.
    Oil rings are usually the culprit.
    Years ago I re-ringed a customers GLD under his orders not to rebore and go oversize pistons. It was hard to start and smokey so I took it out on a local highway to settle in the rings but it "deiselled" on its oil. Back to the workshop where I stuck a different brand of rings in it, still was the vsame so it eventually got a rebore and larger pistons. That car went like a dream afterwards and 15 years on it is still perfect. Go the catch tank/bottle for the moment I would suggest, while you think about stripping it.
    Andrew
    • #17
      2. install a catch can in the vent system. you can go rudementary (like a jar with an in and out) or fancy (pro-vent system). both will work.
      You've seen the one on my car. that's what we mean by rudementary.
      • #18
        an educational thread
        I learned something!
        Spark ignition is a threatened species
        Biodiesel is the best emission control money cant buy
        MK1 5 door Mexico Beige 5/79 Golf GLD 1.5
        • #19
          you and me both
          • #20
            jesus friggin christ a lot of that went straight over my head, but i think basically u are all saying it is dot or on its way to being dot. i do understand the catch bottle stuff so i will try that for now. am i looking at bick bucks for the re ringing and all the other stuff??
            • #21
              stay tuned
              we can help you nurse the engine a while further but in terms of fixing the problem you are probably better off buying a new (second hand) long motor. If you want to bite the bullet and rebuild the old engine it will involve lots of work and it will always be a 1.5. Having said that I love my 1.5 and a few have said that if they can be made strong enough to take the horsepower they rev like crazy. The easy way out is to buy a 1.9 in a box with a five speed attached.
              • #22
                cheers mate, if this does happen again in the meantime and turning the key off does not stop the engine from revving its tits off, wtf do i do to stop it
                • #23
                  Block the air intake.
                  Performance Tunes from $850
                  Wrecking RS OCTAVIA 2 Link
                  • #24
                    Surely you could stall the engine by putting it in gear and putting the brakes on? Or driving into a wall. That way you have to replace the engine
                    Mk3 Golf Tdi about to sell
                    Mk 1 Golf GLD somewhere in a paddock!
                    Mk1 Golf Cabriolet
                    MK2 Golf Turbo diesel engine and 5 sp gearbox
                    • #25
                      Block the Intake
                      Transporter is right many earlier diesels simply blocked air to the engine with a baffle in the intake operated by a cable to stop the engine. This was before fandangled electric fuel shutoff solenoids. Dropping the vehicle into gear could cause serious damage to other components not to mention dangerous to anyone around the vehicle.
                      • #26
                        not really mate - its not all bad news. a ring set will set you back less than $200, and if you're keen to give it a go (you can do it with engine in car) you could pull the sump, head and pistons, and just re-ring the engine and give the head a clean up. all you would need in parts is a headgasket and the rings, and you'd learn a LOT along the way. even the humble haynes is good enough to get you through something like this.
                        with diligence and care ,you could do it in a weekend if the pistons and bores aren't bad it will go many more trouble free km's. .. or there's Andrew's scenario
                        '98 Mk3 Cabriolet 2.0 8V
                        '99 A4 Quattro 1.8T
                        • #27
                          think budget
                          If you want to bite the bullet and rebuild the old engine it will involve lots of work.
                          I have become a bit anal in my old age and my OCD is becoming worse I wouldn't be able to help myself and I would zero time it. Id forgotten how hard it was with my first cars especially getting into this Golf now.
                          That being said gldgti is right it would be a very good learning experience for you lawny, and with a digital camera and some help from the manual and the forum It can be done in a reasonable time at a very reasonable cost if everything is ok internally.
                          We are all friendly here and I will try my best to help you. Mechanical skills are very underated in today's world but will always stand you in good stead.
                          Dive in mate
                          • #28
                            Dive in mate
                            here here. chicks dig it too
                            '99 A4 Quattro 1.8T
                            • #29
                              just before you pull the motor to bits there is one other potential cause of this problem. If your brake booster diaphram is leaking, the vacuum pump will instead of providing vaccum will pump air. The vacuum pump discharge is to the crankcase. The crankcase vents to the inlet via the camshaft cover which is full of atomised oil off the cam lobes. You will hopefully have noticed how awful your brakes are if this is the culprit
                              Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
                              White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
                              Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
                              • #30
                                and i would be very cautious putting new round rings in oval bores. remember that the rings that are in there have worn with the bore and will probably fit better than a new set.
