In your shoes I'd also be going Penrite. Their website has a great oil recommender-er. If I didn't need this 507 high shear stuff and have a easily ash blocked DPF I'd be penriting the TDI now.
penrite have a 507.00 approved oil... its called HPR enviro-thingamabob
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
"In warm weather, a good-quality non-synthetic oil meant for diesel engines with CG-4 or CH-4 ratings may be used. They're not suitable in cold weather due to reduced cold-pumping properties, and it's prudent to shorten the oil change interval because non-synthetic oils may not resist breakdown at high temperatures as well as the synthetic oils (remember that turbocharger). These oils are much easier to find. These include:
Mobil Delvac 1300, 15w40
Shell Rotella T, 15w40
Chevron Delo 400, 15w40"
in other words, in a warmer climate like here in australia (generally), a good quality diesel rated 15W oil is a sensible choice. this is why i use the penrite.
i'm considering changing to the fully synthetic penrite for the winter though...
'99 A4 Quattro 1.8T
Did you consider Amsoil Marine and Diesel oil 15W40 ?
That amsoil oil isnt properly rated, the only amsoil ones are 5w-40 Synthetic European which is $18 per quart or the 10w-40 high performance which is $90 for 5L.
Distributors only. There is no Amsoil on the shelves.
Look in the White Pages or Yellow Pages.
I buy some of Amsoil products.
Amsoil Power Foam cleans the combustion like nothing on the market, Cetane Improver is good, Engine Flush is excellent, P.I. petrol additive is average.
Amsoil oils are well priced if you compare them to oils available from shops.
