So much psi is safe?
2.0 TDI - how much boost ?
i run 28psi on my gtb1756vk, might be going up to 30/32 soon, peter from 3bar tuning in melbourne runs up to 40psi in his awd tdi jetta using a gtb2060vklr turbo07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
Whilst this thread is active, what boost gauges are you guys running and how did you tap them?Originally posted by bgcarter1 View Posti run 28psi on my gtb1756vk, might be going up to 30/32 soon, peter from 3bar tuning in melbourne runs up to 40psi in his awd tdi jetta using a gtb2060vklr turbo
Six months ago I fitted a Redarc dual boost/EGT gauge to my 2.0 TDI Rok by drilling and tapping a 1/8" BSP thread into the hard plastic tubbing coming from the intercooler prior to the inlet manifold.Originally posted by gldgti View PostEasiest way is to drill a hole into one of the hard plastic boost lines and epoxy (the good grey stuff) a plastic fitting into the hole.
The gauge has digital boost and electronic analogue EGT readings and you can personally set up its internal beeper and/or light flashes at any pre determined warning points.
My boost warning goes off at 30 psi
which can be achieved quite easily and at surprisingly low RPM.
My overall results are very similar to post #8 with the major difference being the Rok is bi-turbo and fixed vain.
If you reckon these boost pressures are high then google Land Rovers new engine as it makes something like 54 psi. [emoji15]
Cheers dave
Tried to PM you but your inbox is full,Originally posted by gldgti View PostEasiest way is to drill a hole into one of the hard plastic boost lines and epoxy (the good grey stuff) a plastic fitting into the hole.
I was wondering if you could elaborate on this "Easiest way is to drill a hole into one of the hard plastic boost lines and epoxy (the good grey stuff) a plastic fitting into the hole."
I am not really sure which pipe to plug into, I don't really know my way around the engine bay that well.
I have a mk5 GT TDI, my current air intake actually has a small vacuum tube coming out of it too, would it be bad to just piggy back that?
Or could you point out where I need to tap into
Thanks mate
May I suggest a solution to consider? Get a cheap bluetooth OBDII interface from ebay. Download the Torque app from iTunes or Google Play and set it up on your smartphone or if you want to go fancy pick up an iPad mini or 7inch Android tablet and mount it on your dash.
The Torque app will display the turbo boost (in digital or gauge form) amongst a host of other data you can get from the ECU and the display can be customised on the go (after you have stopped the vehicle in a safe location
). It will save you trying to learn your way around the engine bay with a drill, as it has for me.
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
If the sedans are the same as Amaroks then you can't get a reading above 22.something psi out of the OBD11 port as it to do with computer talk that is above my pay grade.Originally posted by feenix74 View PostMay I suggest a solution to consider? Get a cheap bluetooth OBDII interface from ebay. Download the Torque app from iTunes or Google Play and set it up on your smartphone or if you want to go fancy pick up an iPad mini or 7inch Android tablet and mount it on your dash.
I could find out more detail if required though.
Cheers dave
I think I just prefer the charm of the analog gaugeOriginally posted by feenix74 View PostMay I suggest a solution to consider? Get a cheap bluetooth OBDII interface from ebay. Download the Torque app from iTunes or Google Play and set it up on your smartphone or if you want to go fancy pick up an iPad mini or 7inch Android tablet and mount it on your dash.
is there something like this for the 2.0 TDI's?
ECS - 003621ECS01A - 2.0T Billet Boost Tap Assembly
The issue with the OBDII reading is simply that the factory MAP sensor is usually 2.5Bar absolute.... which equates to about 22.5psi gauge pressure.
Hence you wont see a number higher than that on the e-gauge, even though a stock tune car will spike above that pressure anyway.'07 Touareg V6 TDI with air suspension
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I learn something new everyday. Is there an aftermarket MAP sensor that will go higher than 2.5 bar?
Good luck weonarok with learning your way around the engine bay with a drill.1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
How does it determine overboost then? I know my OBD reads to 255, but my car overboosts due to stuck vanes.Originally posted by gldgti View PostThe issue with the OBDII reading is simply that the factory MAP sensor is usually 2.5Bar absolute.... which equates to about 22.5psi gauge pressure.
Hence you wont see a number higher than that on the e-gauge, even though a stock tune car will spike above that pressure anyway.Richard
2007 Black Jetta 103TDI Manual, 18s, body kit + rear spoiler
2001 Landcruiser FZJ105 Manual - The petrol guzzler!
