Originally posted by mikinoz
View Post
tie. I check the tube weekly; drain it probably every 3 months. So far I’ve done 65,000km. Top up between 7,500km oil changes is around 1/2Lof oil; I top up
only when the oil level gets bellow min. mark on the dipstick.
I believe that changing the engine oil more frequently has positive effect on the amount of the blow-by gas since the clean oil will give a better piston seal
hence the less of the blow-by gas.
