Hello brains trust,
My Jetta has 152,000 kms on it, and has just developed an audible boost leak. Still goes fine, just hisses once the MAP gets over about 170 on my OBD reader. On the weekend, I pulled off the two hoses to the bottom of the intercooler and cleaned the O-rings and metal connectors. There was a fair bit of oily/dirty gunk on the outside of the intercooler connections. I've wiped this off and cleaned the plastic under engine tray to see about new gunk. Since cleaning these bits, it seems to happen even more. All the clips and connectors seemed to be in good condition. I cleaned the top accessible end of the pipe into the intake manifold also.
Is it likely to be leaking around the O rings? Do any of the hard plastic pipes crack? Is it likely to be the intercooler itself?
I get overboost limp if I bring on the boost at over 2000 rpm for an extended time, such as climbing hills at 110km/h on the freeway.
I suppose that at some stage, if the leak gets bad enough, the car won't drive real well?
Many thanks,
Richard
Many thanks,
Richard
