Keeping Right side Footrest cover in place
  • Keeping Right side Footrest cover in place
    Hi
    I got a set of the stainless footrest covers that match the brake and accelerator pedals
    The kit came with screws and washers for the left one and they worked well
    (although I countersunk the holes instead of using the cup washers)
    But the right one is held on with double sided tape - well, is supposed to
    almost every time I put my foot on it I can feel it move so the tape is not too effective
    When vacuuming the floor a simple bump with the vac hose and it falls off
    My preferred fix would be a small screw top and bottom but I have no idea what is behind the panel
    Question is
    Has anyone else fitted these and if so have you had same problem
    If "yes" what was the fix
    Thanks in advance
    Hi I put heaps of thin double sided tape on mine so it does not show through and preped the surface with acetone before sticking it on. It's never moved in the 2.5 years it has been on. A few small self tapping screw should be OK as well but I have not needed them.
      Only use the right foot rest when cruise is on anyway.
        Thanks for the reply
        Any particular double sided tape or just general purpose type ??
          I used 3m brand from Bunnings don't buy cheap stuff
            meant to add to last post
            For me that is a lot
            We have a local 60kph and an 80kph speed zone where the "Pigs" regularly frequent with their hand held money making cameras
            So I always use Cruise Control in those areas to avoid accidentally picking up a few kms
            Thanks prh1973
            I will get some and give it a go
              All Fixed
              I used 3m brand from Bunnings don't buy cheap stuff.
              OK, went to Bunnings and they only had "Scotch" brand + some others I haven't heard of - no 3M
              Spent an awfully long time going through all the types/brands etc
              The best Scotch branded tape was about 1/2 kilo per metre
              A "Perma" brand "Mounting" tape had a capacity of 20kg per metre but was a bit dearer - that's what I ran with - It's clear as well
              Like chalk and cheese compared to the original tape.
              Unfortunatley it was 20mm wide and I had to cut it in half width wise - took a bit but got there
              Anything it touched it stuck to.
              Covered pretty well all the underside of the foot rest
              Didn't have any acetone so I used iso propyl alcohol to clean the plastic
              Carefully positioned and pressed on - instant adhesion -
              Don't think you could get it off if you wanted too !!! And that's with less than 50% of the bond strength
              Just shows what garbage tape they use in the first place
              Thanks again for the "heads up"
                Sounds about right. Especially if it was from eBay.
                  A lot of Scotch brand is actually 3M if you look carefully at the packaging
                  I bought this in Walmart in the USA but is available at Bunnings. Is identical to the 3M stuff I bought off 3M themselves
