Hi All
Looking for some suggestions, I've had a bit of run of bad luck with the car the past 2 weeks. Firstly, I left the key in the ignition at work for the day (our private car park requires attendant to move car from time to time). Key was inserted but turned off but with all the systems and stuff that come alive even just when inserted the battery died. I had to get a jump start, thought nothing of it.
Following week I got a tyre pressure light on dash. Inspected the wheels found a massive screw through front right on the conrner of sidewall and tread. Pressure a bit low, 30PSI, so I thought a slow leak. I needed new fronts anyway so this was a good excuse and on Saturday got 4 new tyres. When the old tyres came off there were 3 nails in the rear tyres as well but in the the tread...no pressure issues.
Drove up to the country on Sunday, oil warning light comes on. I checked my oil about 3000km ago and it was 3/4 towards max. In the first 15,000km my car used less than .5l so I haven't checked it more frequently than every 5000km. This time it was JUST above min. I was soo stressed, immediately bought VW504/507 oil and topped up.
Driving home tonight, the coolant system warning light has come on flashing. The oil temp is normal, actually a bit lower than normal. Im freaking out again.
THing is, all this has started with a flat battery and now its got me wondering what might be going on. The tyre warning seemed legit, though considering the only 2psi drop and the fact there were nails/screws in all the tyres I wonder...
The oil warning is obviously legit, but why such a sudden drop in oil?
Coolant system - coolant is below Min line.
The car was serviced at 15,000 which is 7000kms ago. There have been no issues to date.
Obviously the next step is to get it to a mechanic, and therein lies the problem, I've done the Full TBE, Intake, ECU stage 2, Stereo, KW Coilovers. If this becomes a warranty discussion Ill be going through the dreaded back to stock exercise.
Does anyone car to guess if this might just be electrical system playing up or someone much more serious?
