Originally posted by RoccoR
View Post
Scirocco r mods
It isnt diameter you need to be worried about but spoke clearance...it is all dependent on the wheel.Originally posted by RoccoR View PostYeah I already have the BBK cos I had them on my GTI Mk6 and now putting them on my scirocco. If they fit on the GTI with 18" rims I'm almost certain that the 19" talladegas will swallow them quite easily. The rotors are 375mm and I know they'll fit also.
By the way.... according to the kit part number...it would appear the discs are 355mm which is a more common size..
Good luck with it...Pics when finished would be good.Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
Cup Rear Spoiler, VMR V718 GM rims, APR Tuned, Brembo 6 pot BBK, Eibach Pro-Kit springs, Low line RVC, Exhaust flap delete
This is my BBK from AP racing. Similar to the ones used on the Scirocco Cup cars.
The 2 piece rotor weigh only 6.9 kg! (OEM 12kg)
The 6 piston monoblock calipers, custom bracket and pad weighs 3.2kg (OEM 9kg)
Total saving of 10kg of unsprung weight per corner!Last edited by Rev 555; 12-07-2012, 08:23 PM.
I hope you are going with ceramic pads too...no more brake dust...then...Originally posted by Rev 555 View PostThis is my BBK from AP racing. Similar to the ones used on the Scirocco Cup cars.
Total saving of 10kg of unsprung weight per corner!Candy White Scirocco R DSG with Panoramic Sunroof and RNS510 Sat Nav, tint
Just on my way to pick up my scirocco after having APR DP, big brake kit and engine mount insert installed. Of course all of this with an APR stage 2 flash. Hmmmmmm it's going to be interesting no doubt.
I'll hold of on the HPFP for the next month or so.
