Been slowly working away on the car over the past week.
Pitting looks bad in the photo but its really quite fine. The floors are still pretty sound. If it had have been left another year or two it would be a different story though id say..
Heres a pic after the first coat of POR-15 treatment (yes I cleaned up all the rust first with a flapper wheel/wire wheel. Will key the surface and do another coat after a little bit of welding is done to the rust hole. The stuff dries rock hard so I can see why they say not to let it dry on your skin! I spilled a small amount on the concrete and its not going anywhere!
The worst of the rust. Ive started cleaning up the area in prep for welding up this little hole but still needs a bit more work.
donor low mileage 2E engine
crossflow head from a Seat cordoba I believe and some other goodies I have collected
I have all the parts from the head kicking about now. Just need to drop if off to get it all pieced together. The next step will be figuring out which head gasket kit im gonna need. It looks as though I should get away with an ABA gasket kit.
I wont be touching the bottom end at this stage.. Its a pretty fresh engine so no point really.
