Finally it is looking like it is going to happen - the Scirocco returns !! !!!
Source
Source
New VW coupe confirmed
Matt Campbell
November 26, 2010 - 5:11PM
The turbocharged Scirocco is coming down-under.
Volkswagen's sporty two-door Scirocco is coming to Australia.
Volkswagen Australia will widen its appeal even further in 2011, with managing director Anke Koeckler confirming the Scirocco sports coupe is "a matter of when, not if".
Speaking to Drive at the launch of Volkswagen's new pocket-rocket Polo GTI, Koeckler declined to say when Australians should expect to see the coupe, but didn't rule out a surprise arrival in 2011.
"I knew you would ask this question," said Koeckler. "It's an amazing car, and I love this car as well - that's why I'm working on that.
"It's probably more a matter of when [it will arrive]," Koeckler told Drive.
Quizzed further on the timing of its arrival, Koeckler grinned at the suggestion of a 2011 release.
"Could be," she said. "We're going to work on that. I know its a great car, and I know you guys are looking forward to it."
The turbocharged Scirocco is based on the same underpinnings as Volkswagen's Golf, and, as Drive has previously reported, VW has been tentative to bring the coupe in alongside the GTI for fear of sales cannibalisation.
When it does make it to Australia, the Scirocco isn't certain to be available in multiple specifications - the most likely candidate for Down Under being the top-of-the-pops Scirocco R.
That model outguns VW's quickest Golf with a 195kW power output, and manages a hefty 350Nm of torque (the Golf R uses the same engine, though in a slightly detuned form at 188kW and 330Nm).
Koeckler confirmed that Volkswagen's soon-to-be-released micro city car, the Up, won't be appearing locally in 2011.
Koeckler said the Up (if that's what it is to be called) would be a struggle to justify for local sale, with high costs of manufacture limiting the possibility of a sub $15K city car from the brand.
The replacement for the New Beetle (which is likely to simply wear the "Beetle" moniker) may also struggle to make an appearance before 2012.
Koeckler did, however, confirm the release of several key new models for Volkswagen in Australia in 2010 - including the all-new Passat (1st quarter), Jetta (3rd quarter) and Touareg (mid-year).
Matt Campbell
