:: ECS Tuning :: VW B5 Passat Front Big Brake Kit - Click Here !!!
  • :: ECS Tuning :: VW B5 Passat Front Big Brake Kit - Click Here !!!
    Improve braking performance with an ECS Tuning Big Brake Kit. Bolt on larger 312mm GEOMET coated rotors in either slotted or cross drilled & slotted.
    Then mount your original calipers away from the spindle centerline with the kit's larger caliper carriers for added mechanical leverage and shorter stops.
    No need to cough up extra bucks for a set of larger calipers or brake pads. This upgrade conveniently reuses the stock pads and calipers.
    Lower price. Less expense. Surer stops.
    http://www.ecstuning.com
