:: ECS Tuning :: VW MK6 Jetta 1.8|2.0T Gen3 ECS Boost Tap & Gauge Kit - Click Here !
  • :: ECS Tuning :: VW MK6 Jetta 1.8|2.0T Gen3 ECS Boost Tap & Gauge Kit - Click Here !
    ECS believes your boost gauge should be easy to see, blend with your interior, and provide you with the most accurate readings at all times.
    Other methods of acquiring a boost/vacuum signal can lead to skewed data being sent to your ECU, ultimately dropping engine power.
    Engineered specifically for the Gen3 engine, we designed our Throttle Body Boost Tap with 2 ports and our Manifold Port Boost Tap with 3 ports, so you have multiple options to provide the strongest manifold signal. You can be certain that all critical data is not affected and your engine's power is not lost.
    http://www.ecstuning.com
