VW 4x100 ECS Wheel Spacers -
ECS Tuning lets you tweak your stance--or swagger down the road with a monster offset.
Set up a more aggressive appearance by pushing the wheels out from the body. Hubcentric spacers can also serve as a cure for wheel rubbing when utilizing an aftermarket suspension setup.
ECS offers a wide variety of sizes to give you the ideal stance for your specific needs and tastes - every ECS spacer is made from a high quality 6061-T6 anodized black aluminum to keep weight to a minimum and effectively resist corrosion.
Made specifically for your 57.1mm center bore VW hub.
