VW MKIV Golf Wheel Stud Conversion Kits -
Why use wheel studs instead of wheel bolts?
When removing and installing wheels that utilize the factory wheel bolts, excessive, unnecessary wear is placed on the wheel hub itself.
This premature wear on an expensive component is costly and difficult to repair.
Wheel studs also allow the use of varying length wheel spacers - a highly convenient feature for those that anticipate using different spacer size setups in the future.
Both conical and ball seat lug nuts are available for a maximum of 10mm or 20mm wheel spacer use.
