:: ECS Tuning :: VW MKIV GTI 1.8T ECS Aluminum Coolant Split Pipe - Click Here !!!
  • :: ECS Tuning :: VW MKIV GTI 1.8T ECS Aluminum Coolant Split Pipe - Click Here !!!
    Plastic coolant connections are consistently subjected to heat shock, corrosive substances, & chemical degradation.
    Considering the importance of adequate engine cooling, coolant fitting upgrades are always a wise investment.
    ECS has developed a cast-aluminum replacement for the fragile plastic coolant split pipe fitted to the VW MKIV GTI.
    This highly failure-prone fitting can be responsible for a sudden, major coolant leak – over-heating engine internals and causing catastrophic damage.
    ECS-assembled kits including installation hardware and coolant are also available.
    http://www.ecstuning.com
