:: ECS Tuning :: VW New Beetle 2.5L Water Pump Replacement Kits - Click Here !!!
  • :: ECS Tuning :: VW New Beetle 2.5L Water Pump Replacement Kits - Click Here !!!
    VW New Beetle 2.5L Water Pump Replacement Kits - Starting At $124.95!
    When replacing your water pump, what happens in your cooling system is that the burden of wear transfers to a different part, one that will then need to be replaced itself at a later point.
    By attending to the entire water pump system at the same time, the system remains a self-contained, quality high functioning unit.
    ECS has assembled a convenient Water Pump Replacement Kit complete with all gaskets, bolts pulleys, tensioners, securing bolts, and even a gallon of coolant, helping you do the job the first time the right way.
    http://www.ecstuning.com
