VW MKIV Jetta Tie Rod Service Kit - Starting At $66.95!
The tie rods are the link between the steering rack and the steering knuckle on your MKIV Jetta. They utilize a ball socket to articulate movement while driving, but they will eventually wear out, causing uneven tire wear, loose steering, and noises over bumps or around corners.
The experts at ECS Tuning have built these complete tie rod kits which will allow you to get the job done right the first time. Replace your tie rods today and gain back the tight, responsive steering your car once had.
