VW MKIV GTI 1.8T ECS Aluminum Coolant Split Pipe - $49.95!
Plastic coolant connections are consistently subjected to heat shock, corrosive substances, & chemical degradation. Considering the importance of adequate engine cooling, coolant fitting upgrades are always a wise investment.
ECS has brought you a cast-aluminum replacement for the plastic coolant split pipe on the MKIV 1.8T. This highly failure-prone fitting can be responsible for a sudden, major coolant leak – over-heating engine internals, causing catastrophic damage.
The ECS coolant split pipe will withstand excessive abuse, restoring faith in your cooling system.
