:: ECS Tuning :: VW MKVI Jetta Traction Control Button Retrofit Kit - Click Here !!!
  • :: ECS Tuning :: VW MKVI Jetta Traction Control Button Retrofit Kit - Click Here !!!
    VW MKVI Jetta Traction Control Button Retrofit Kit - Starting At $99.95!
    You've probably noticed a cut in power when accelerating out of a turn or from a stand still. The MKVI Jetta does not feature an in-cabin switch to turn off the traction control system, but ECS Tuning offers a complete kit to give you this function.
    Using a proprietary harness designed by ECS and an OEM ESP switch, this kit installs seamlessly for a factory look. Some coding may be required. You're just a DIY install away from laying down some rubber!
    Our installation PDF will guide you though the process. Put traction control back where it should be, your right foot!
    For our install PDF please click - Here
    http://www.ecstuning.com
